Viewing 4 reply threads
    • Kyle JacksonKyle Jackson
      @krjackson
      I have version 0.1.2 of Stone Designer that came with the screen I purchased to prototype with. The user manual shows many different keyboards available, and I need both the float and int keyboards. However, I only have the option to use kb_default, not any of the others described in the manual.
      Do I have an older version of the software? Am I missing something?
      Thanks,
      Kyle
    • Patricia RenPatricia Ren
      @patricia
      Your version is too old resulting in features that are not perfect, the new version of the software has solved your needs. Please be careful to check your email.
      @krjackson
      Thank you for the prompt response, Patricia. I have received the updated software and will try it later today.
      @krjackson
      Hi Patricia, the version you sent me seems to be 1.0.0, yet I have the same problem with the keyboard. My only option with an edit or spin edit is kb_default.
      Any suggestions?
        @patricia
        hello, first of all you need to add your keyboard from project, and only after adding it can you set it at the keyboard.
        You can refer to my operation.
      @krjackson
      Thank you, Patricia! That’s exactly what I was looking for. I notice this information is also in the documentation provided, and I just overlooked it.
      Thanks for all your help!
