Viewing 2 reply threads
    • massimo.bolesomassimo.boleso
      @massimo-boleso
      hi, I recently bought STMUNO-01 but I have some problems using it.
      I’ll start from the beginning, I have a HMI STWI070WT-01 that I used with your USB UART converter and my Arduino UNO, everything works correctly, I wanted to buy STMUNO-01 to have everything in one board.
      but even checking with an oscilloscope I note that I never send anything to HMI, so I can’t really understand where I’m going wrong. do I have to modify some JMP on the STMUNO? I also tried to send commands directly from serial but nothing to do
      Thanks for the help 🙂
      attach a simple program that I use for test
      @massimo-boleso
      solved … I forgot to do the jump from lcd_rx to 1-tx as indicated in the instructions
      sorry 😉
    • stoneitechstoneitech
      @forum
      The results are delightful.
