Brian EdwardsBrian Edwards
@bedwards1000
Should the type be a widget or a label?  When I send text I use type label and it works well.
ST<{“cmd_code”:”set_text”,”type”:”label”,”widget”:”AlertText”,”text”:”Sample Text”}>ET
But your modified commands use a type widget to update the label.
The commands you sent did not work either.
ST<{“cmd_code”:”set_visible”,”type”:”widget”,”widget”:”AlertText”,”visible”:false}>ET
Did nothing.
ST<{“cmd_code”:”set_font_size”,”type”:”widget”,”widget”:”AlertText”,”state”:”normal”,”size”:32}>ET
Did nothing.
ST<{“cmd_code”:”set_color”,”type”:”widget”,”widget”:”AlertText”,”color_object”:”bg_color”, “color”:00000000}>ET
Set the background color to white but I can’t seem to set it to any other color.  what would the command be to set bg_color to red.
