Viewing 5 reply threads
    • Brian EdwardsBrian Edwards
      @bedwards1000
      Is it possible to change the properties of a label? (visible, font_size, bg_color, text_color) I need to use a label as a text box.  Sometimes it is necessary to change the background color to red.
      I have tried various combinations of the following commands and nothing works.  I can update the text on the label with no problems.
      ST<{“cmd_code”:”set_visible”,”type”:”label”,”widget”:”AlertText”,”visible”:false}>ET
      ST<{“cmd_code”:”set_font_size”,”type”:”label”,”widget”:”AlertText”,”state”:”normal”,”font_size”:32}>ET
      ST<{“cmd_code”:”set_bg_color”,”type”:”label”,”widget”:”AlertText”,”color_object”:”bg_color”,”color”:00000000}>ET
      This is the definition of the widget.
      <label name=”AlertText” x=”225″ y=”386″ w=”282″ h=”82″ text=”Label” visible=”true” style:normal:font_size=”24″ style:normal:border=”none” style:normal:bg_color=”#ff4500″ style:normal:text_color=”#147a14″/>
      Is what I am trying to do possible?  If not, how do I accomplish printing text to the screen and changing the background color?
      Thank you
    • Patricia RenPatricia Ren
      @patricia
      Hello, I will test your question in the next few days and get back to you.
      Please be patient and thank you for your cooperation.
      @patricia
      ST<{"cmd_code":"set_visible","type":"widget","widget":"AlertText","visible":false}>ET
      ST<{"cmd_code":"set_font_size","type":"widget","widget":"AlertText","state":"normal","size":32}>ET
      ST<{"cmd_code":"set_color","type":"widget","widget":"AlertText","color_object":"bg_color", "color":00000000}>ET
      There was a partial problem with your command, it has been modified for you, please test it with the above command.
      If there are still problems please communicate with me.
      @bedwards1000
      Should the type be a widget or a label?  When I send text I use type label and it works well.
      ST<{“cmd_code”:”set_text”,”type”:”label”,”widget”:”AlertText”,”text”:”Sample Text”}>ET
      But your modified commands use a type widget to update the label.
      The commands you sent did not work either.
      ST<{“cmd_code”:”set_visible”,”type”:”widget”,”widget”:”AlertText”,”visible”:false}>ET
      Did nothing.
      ST<{“cmd_code”:”set_font_size”,”type”:”widget”,”widget”:”AlertText”,”state”:”normal”,”size”:32}>ET
      Did nothing.
      ST<{“cmd_code”:”set_color”,”type”:”widget”,”widget”:”AlertText”,”color_object”:”bg_color”, “color”:00000000}>ET
      Set the background color to white but I can’t seem to set it to any other color.  what would the command be to set bg_color to red.
      @bedwards1000
      Also, how do I update text on a list item contained by another widget?  I want to update alert_1 to alert_3 in the following data.
      <label name=”AlertText” x=”225″ y=”386″ w=”282″ h=”82″ text=”Label” visible=”true” style:normal:font_size=”24″ style:normal:border=”none” style:normal:bg_color=”#ff4500″ style:normal:text_color=”#147a14″>
      <list_item name=”alert_1″ x=”0″ y=”0″ w=”282″ h=”16″ text=”Alert 1″ style:normal:bg_color=”#1e90ff” style:normal:text_align_h=”left”/>
      <list_item name=”alert_2″ x=”0″ y=”16″ w=”282″ h=”16″ text=”Alert 2″ style:normal:border=”none” style:normal:bg_color=”#90ee90″ style:normal:text_align_h=”left”/>
      <list_item name=”alert_3″ x=”0″ y=”32″ w=”282″ h=”16″ text=”Alert 3″ style:normal:bg_color=”#1e90ff” style:normal:text_align_h=”left”/>
      <list_item name=”alert_4″ x=”0″ y=”48″ w=”282″ h=”16″ text=”Alert 4″ style:normal:text_align_h=”left”/>
      <list_item name=”alert_5″ x=”0″ y=”64″ w=”282″ h=”16″ text=”Alert 5″ style:normal:text_align_h=”left”/>
      </label>
      @patricia
      Hello, can you send your test project to the email address of the person who sent you the tutorial on how to change your logo and we will test your problem once we receive it?
      Thank you for your cooperation.
