I have tested with the virtual serial port, it seems that the simulation of this part is missing. But it is working on the actual screen.
Your setting is correct. You can tested with the actual screen.
To download the project, you need to use the USB disk offline download function. Download the project in to a USB disk, and plug into the display. The USB mini port on the converter is just for the data communication.
