Thanks for contacting us.
According to the image you shared the button setting is correct. And I have also tested on my side without any issue.
Can you share more image for other button and data variable setting? Or you can directly send me the project so I can check for you.
Thaks for your reply.
Here are other images, I have tested the project using Virtual serial port screen function because I have another issue, I could not download in to my tft module, I think some configuration is missing (USB has not been detected).
Thanks for your support.
You must be logged in to view attached files.I have tested with the virtual serial port, it seems that the simulation of this part is missing. But it is working on the actual screen.
Your setting is correct. You can tested with the actual screen.
To download the project, you need to use the USB disk offline download function. Download the project in to a USB disk, and plug into the display. The USB mini port on the converter is just for the data communication.
