I have one STWI080WT which is about 8 months old now and I want to upgrade the firmware to the latest version.
One of your technical staff sent me the latest firmware, but I can’t upload it to the LCD. I tried using the U Disk with the LCD set to host and also using the Serial Port with the LCD set to Device.
I was also given an instruction/procedure on how to upload the new firmware. First I powered up the LCD and set it to Host. The U Disc contains the StoneHMI.bin (STONE\bin\StoneHMI.bin).
Then I inserted the U Disk and waited 5 to 10 secs but nothing happens on the LCD. I also sent the Reset command using the serial port but nothing happens.
I tried this a few times but I can’t get it to work.
The LCD only shows the STONE logo on power up then the LCD goes to a blank screen.
Can you please send me a video instruction in case I am doing it wrong?
Please advise.
Thanks.
We will contact you. Please check your mail
Ok Patricia,
Thank you very much.
