Viewing 4 reply threads
    • John GJohn Gell
      @jgell24
      whenever I try to set the value of a Slider or Progress bar using
      example ST<{“cmd_code”:”set_value”,”type”:”progress_bar”,”widget”:”progress_bar”,”value”:40}>ET
      The HMI returns immediately with multiple responses. with a changing float value.
      40.02, 40.05, 40.09 etc..
      This happens with both sliders and progress bars, from the documentation I would assume that the “set_value” commands should be passive?
      Any Ideas? These multiple returns are overloading my UART buffer..
      Hello
      Our engineer has contacted you about this problem, please confirm.
    • John GJohn Gell
      @jgell24
      Yes, ongoing now via email.
      Thanks..
    • deep3dlabdeep3dlab
      @deep3dlab
      Hi,
      It is happening the same problem to me.
      Could you tell me whether you resolved it ? And how ?
      Thanks in advice
    • WuChaoWuChao
      @wuchao
      Hi sir,
      Thank you for your question. What you described should be, for example, the initial value is 10, and you want to set it to 20. At this time, the system will show the changes from 11/12/13/14/15…19/20 through animation come out. And in this change process, there will be a return value.
      This setting is a reserved function for the needs of some customers, because some customers need the data of these intermediate processes. And you can ignore the intermediate data if you don’t need it.
      Also, this issue has been fixed in newer versions of the firmware. We already have only final return values in newer versions of the firmware.
      I have sent you the new firmware by email, please check and download it in time. In addition, I also shared the latest GUI design software, please download it before expired.
      If you have any questions about re-purchase or tech support, you can also contact me directly at any time: chao@stone-hmi.com / WSAPP 008613526285568
      Best Regards,
      Chao
      Stone Tech
