Viewing 4 reply threads
    • retnavairretnavair
      @retnavair
      I use ttl to serial module direct connect module’s din and dput, the data comes out with garbage code, how do I do it?
      <audio style=”display: none;” controls=”controls”></audio>
      See if the screen is a ttl port? There is a short pad option for ttl and 232.
      @retnavair
      I’ve tried it all switch and it’s the same, if I transfer data from the mini USB on the pad, it’s fine. But now I want external devices and this problem occurs.
      The TTL to the serial module is fine and I’ve tried both.
      That’s the problem with the baud rate.
      @retnavair
      If you can’t connect it, you’ll have to communicate with your computer. Is there any way to connect an external serial port?
