Viewing 17 reply threads
    • 270ti270ti
      @270ti
      I use STC070LT-01Stone HMI.
      The HMI does not start properly. After the HMI and MCU are started (powered on) at regular intervals, the HMI does not reply to the MCU. It’s like the HMI doesn’t start the serial TTL communication properly. The only way to fix this is to manually reset the HMI by pressing the reset button on the back of the HMI. This is not a viable solution as we need to open the case to reset the HMI.
      Do you have any suggestion to solve this problem?
      Could you show me your connection diagram and the serial part on the back of the screen.
      Is your screen TTL level already?
    • 270ti270ti
      @270ti
      The screen is TTL level and it works fine.
      Schema is:
      HMI:          MCU:
      GND
      +5V
      D0ut   —   RX118
      DIn     —   TX119
      It is only when I do a cold start (power down to up) in parallel on the MCU and on the HMI that sometimes the HMI starts but do not interpret the command send by the MCU.
      I have to reset the HMI by pressing the rear reset button and then it runs correctly.
      Thanks!
      This may be related to your code, can you provide the code?
      And I have attached the document about how to change the boot logo.
    • 270ti270ti
      @270ti
      bancroft
      I guess you need the code of the MCU? The code is big, tomorrow, I will extract the code with the HMI and try to replicate the problem.
      For the logo, I do not understand your pdf.
      I suppose the Ustorage disk is the disk we have access to by usb on the HMI. Can you please confirm?
      I have tried to copy a “/STONE/logo” folder in the root folder, in the /default folder and in the /default/raw folder of the USB (“U disk) connected to the HMI but this is not working.
      I do not understand what is your folder STONE Demo Project/ 800480/ folder where you create the STONE/logo folder. Is this anywhere on a local disk of the laptop?
      I do not understand where to copy the /STONE/logo folder containing the logo.bmp file (800×480, 24 bits).
      Yes, it is.
      Please check the below picture.
      Put the STONE/logo folder directly in the root directory of the u-disk, and put the logo image in the logo folder.
    • 270ti270ti
      @270ti
      I have tested to copy the /STONE/logo/logo.bmp in the root of the U disk but it is NOT working.
      I have tried with a logo.bmp 800×480 8 bits color and also with 800×480 24 bits color.
      Sorry, the starting logo is still ‘STONE’.
      Do you have some idea?
      Do you have some tracing or error file on the HMI that we can analyse?
      N.B. I have found the starting issue. I was sending commands to HMI very quickly after starting the MCU and this blocked the HMI. Now, I wait three second until the HMI starts completely before sending any command and it looks to be ok.
      May I know when you purchased this screen? could you tell me the version of pcb board?
    • 270ti270ti
      @270ti
      I use a STC070LT-01 Stone HMI.
      I bought it on store.stoneitech.com on 21/12/2022
      Please send me your logo image, I will send you a STONE folder so that you could copy it to the u disk directly.
    • 270ti270ti
      @270ti
      You will find in attachment the logo image, I would like to apply.
      You will find in attachment the .bmp file. It is a test version, I still have to build the final version.
      We do not find any problem when we test your logo.
      Please check the attached video, and please put the STONE folder directly into the U disk for updating.
      https://we.tl/t-7Xo49cH9Qj?utm_campaign=TRN_TDL_09&utm_source=sendgrid&utm_medium=email&trk=TRN_TDL_
    • 270ti270ti
      @270ti
      It does not work on my HMI.
      I am 100% shure to have copy and extract your STONE.RAR file in the root of the Udisk but it is not working on my version of HMI.
      It is exactly what I have tried earlier. I have build the right /STONE/logo folder and put in it the logo.bmp file but with NO result.
      What I can see in your video is that you are not using the same version of the HMI!
      I am using a STC070LT-01 Stone HMI.It is not a green board, it is a yellow board.
      Could you please record a video and send it to me?
    • 270ti270ti
      @270ti
      Here is the video you asked.
      https://drive.google.com/file/d/1xlTMkKHCczT29Pk4KFmMJyqAV2-I3_uw/view-1
      You can see first the Udisk and the e:\STONE\logo folder containing the logo.bmp file and next the restart of the HMI where the STONE logo is not replaced.
      Dear sir,
      You need to do this with a U-disk and not through USB cable.
    • 270ti270ti
      @270ti
      That was my first question what do you mean with “to do this by a udisk”?
      The udisk is the usb disk? How do you access the udisk?
      The following image is the U disk, store the logo image according to the following path.
      STONE/logo/logo.bmp
