Viewing 2 reply threads
    • Anonymous
      Inactive
      Hello there.
      Is possible to rotate a Text Display + or – 90 degrees?
      I am working with a STVI070WT -01  (800X480). I understand its “natural” horizontal position is the 800 pixels side, but I need to use it in a vertical manner, as if it were a phone.
      Thanks
    • Nigel TianNigel
      Member
      @nigel
      Hi Alexander:
      Yes you can use the portrait mode. You need to change the resolution as 480*800 while you are creating the new project.
      And please notice that once you select portrait mode, you need to download by USB disk but not USB mini cable.
    • Anonymous
      Inactive
      Thanks Niegel for your feedback.
      I made it work by using 800*480 + rotating project 90 degrees + using 480*800 pictures. Your comment about downloading the files by using a USB disk and not a USB mini cable was key to success…!
      For some reason I was unable to make it works by following a 480*800 configuration + 480*800 images. I got “Prj resolution error” every time I tryed to download the files on the board.
      Hope this could also help others.
      Thanks
      • Nigel TianNigel
        Member
        @nigel
        Hi Alexander:
        You can try to save the 480*800 file by Windows paint tools and test again. Some times the software doesn’t recognized the resolution if you save the image by some other software.
        You can also send me the image so I can help you to test.
