Please tell me the month you received the lcd, take a picture of the serial number on the back and I will send you the appropriate file
Panel was received 12-14-2020. I have attached the picture of the serial number as requested. Thanks so much for the help, I really appreciate it!!!
Okay, I unzipped the files placed the files in the root directory. I then powered off the display module and powered it back on. Now the device is no longer showing up as a USB device and is not recognized by the Stone TOOL 2019. Also still showing blank screen. Only the red LED is illuminated on the back of the panel.
Yes i used the USB stick.
Format the U disk first, then put the two files in the root directory and plug them into the LCD, U disk FAT 32 format, download the project also with the U disk to see if it can be downloaded. Feel free to contact me if you have any questions.
You must be logged in to view attached files.Okay, I tried as you suggested. I formatted the U disk as FAT 32, then placed the first two files in the root directory. I then connected the U disk to the LCD and powered it on. There was no response form the LCD Just the red LED on the back and a blank screen. I then tried the same process with the next two files you sent. Same results.
I have powered the LCD on first, then inserted the U disk. I still get no response from the LCD, just a blank screen.
