I bought the STWI070WT-01 display six months ago. I’ve set up a relay management project with various pages and various buttons on them. I developed the software on the Arduino using the STONE Serial library. Basically, the display controls Arduino by pressing buttons that control the relays. But the software doesn’t work. Looking for the reasons for the malfunction, I used the AI Thinker software (a serial message viewer) and, by pressing various keys, I obtained the following data packets:
56 D5 D8 D7 FF F1 1F 15 27 19 9D 9D FB 83 75 57 B1 3F
56 D5 D8 D7 FF F1 1F 15 27 19 9D 91 FB 83 75 57 B1 7B
relating to two different buttons. Note that the head and tail characters are the same, only the button identifier changes.
I don’t understand why I get these strange characters. Can someone help me?
Baud rate is set to 115200. For more precision, I connected the display through serial adapter set to TTL, powered with an external DC power supply and connected to PC via USB. Other baud rates generate rubbish. Pressing the same button from display produces the same data packet. Any suggestion from STONE staff?
Hi everyone,
I resolved independently: the P2 jumper setting was wrong. They must be set to RS232 and not to TTL.
In summary, for benefit of those who want to check the communication of the display, it is necessary to use the usb to serial adapter powered at 12 V (jumper P1= PWR). Connect the PC through the USB port, setting jumpers P2 to RS232 (not TTL). The software sscom32e.exe or equivalent is used (for example AI Thinker). The “hexdata” box is activated to correctly see the hexadecimal codes coming from the display.
