    • Clay GradyClay Grady
      @grady
      May I ask if this part of the circuit needs to be changed if we want to sending data to the display screen?
      Using TTL mode, short connect。
        @grady
        Now there is no short connection. In 232 mode, the screen can also send data normally. However, when debugging software sends data to the screen, the screen does not respond, and the same data sent to the simulator is normal
        It has to be short, unless you’re sending 232 data to the screen.If you are sending 232 data, there may be a misconnection.
