I received the STWI080WT-TTL that I recently purchased but I can’t upload our project file because the select switch is missing.
Please see attached picture.
Please let me know which to solder to get into Host mode and which one for Device mode.
Thank you.
<p style=”text-align: left;”></p>Attachments:
You must be logged in to view attached files.If the k600 is dropped, it is equivalent to the dip switch in the DEVICE position, which can only be connected to the PC. If the two pads in position K600 are connected together, it is equivalent to the dip switch in the HOST position. At this time, only the USB flash drive can be connected
Hello Bowei,
Thanks for the info.
I soldered the 2 pads of K600 and used the U-disk. It worked fine.
Thanks.
