Hi STONE
I want the screen to be vertical.
How to rotate the item 90 degrees. I only see 180
Hope to get a quick answer, more anxious.
Thanks!
Hello retnavair
To rotate the project 90 degrees, you must create a new project and set it at the beginning:
All your interface images must be rotated (for example, if your monitor is 800*480, your image resolution must be 480*800)
