Is there a pinout to wire/connect a separate button that will act as the reset button?
While testing, I have to reach behind the board device and find/press that button. And once installed into production if the device ever loses communications, it would be helpful for user to have a reachable button to press and reset the device.
I would prefer reset versus just disconnecting power supply.
There are two very small dots above the reset button on the back, but did not want to risk solder/connecting to them yet.
It is not possible to add a reset signal to the existing communication interface, so the problem you mentioned is not supported at this time.
