Viewing 4 reply threads
    • Kathleen NguyenKathleen Nguyen
      @kathnguyen
      Hello
      I’m trying to have sensor data from the Arduino Uno be shown real time on a graph but also changing the label but I’m unsure of what the syntax is because it doesn’t seem to work. I’ve tried using these commands:
      Serial.print(“ST<{\”cmd_code\”:\”set_text\”,\”type\”:\”label\”,\”widget\”:\”label1\”,\”value\”:66.66,\”format\”:\”%.2f\”}>ET”);
      Serial.print(“ST<{\”cmd_code\”:\”set_value\”,\”type\”:\”line_series\”,\”widget\”:\”line_series1\”,\”index\”:”);
      Serial.print(i); //i is the index
      Serial.print(“,\”value\”:”);
      Serial.print(n); //n is the filtered and adjusted pulse oximeter value
      Serial.println(“}>ET”);
      Any ideas?
    • AndreyAndrey
      @andybig
      In the first command, you set the type “cmd_code” to “set_text” and the parameter to “value”. It is necessary that the command type matches the parameters. If the command type is “set_text”, then the parameter must be “text”, and for the “value” parameter, the command type is “set_value”.
      @kathnguyen
      Oh that was a typo but I believe I did try the set_value and changing the value too but that also didn’t work. When do you use set_text and when do you use set_value? What’s the difference?
      For the second command the parameters match and it still doesn’t work…
    • AndreyAndrey
      @andybig
      If both “set_value” and “set_text” (each with its own parameter) do not work, then you need to check the widget name and the absence of spaces inside quotes in the names of commands, parameters, etc.
      For text widgets, I mostly use “set_text”. I don’t see the point in “set_value”, because anyway, the number needs to be converted to text before inserting it into this command.
      You can test the execution of commands using the terminal program that comes with Stone Designer. So it is much easier to learn the features of the execution of each command than to change the firmware of the microcontroller every time. I just tested using the terminal command
      ST<{“cmd_code”:”set_value”,”type”:”line_series”,”widget”:”line_series1″,”index”:4,”value”:38}>ET
      and it works fine, the line on the graph changes.
    • bowei zhangbowei zhang
      @zbw3366
      There is nothing wrong with the second command. Have you checked the serial port level? Is the communication normal? Can use Serial.println(“ST<{\”cmd_code\”:\”sys_reboot\”,\”type\”:\”system\”}>ET”);Test the one-way communication
