I have designed a screen with a progress bar. It works okay when I connect the LCD to PC and using the sscom32 serial terminal. I can send different values on the progress bar and it responds correctly without problems.
But when I send the same command from the MCU, it doesn’t work. It only stays with the default value and doesn’t vary.
I also tried inputting different values but still doesn’t work.
Any ideas please?
Thanks.
Please check your mail
