Viewing 2 reply threads
    • Mris MrisMris Mris
      @mris99
      The image value widget is a nice one to implement beautiful numeric displays. The minus signal is not provided in the example but it also supports it, nice. One issue is only that the rendered number is always aligned to the left. It is not possible to align the number to center or right.
      Would it be possible to add this settings in the next release?
      @mris99
      Adding a unit after the number would be also great. It could be implemented by a new property “unit_image”. The unit image should be aligned together with the number (left, center or right).
    • Patricia RenPatricia Ren
      @patricia
      Thank you for your suggestion, we will try to develop it regarding your suggestion.
      Until then we hope you can achieve your effect by modifying the position of the controls, thank you for your cooperation.
