Viewing 2 reply threads
    • barretlinobarretlino
      @barretlino
      I´m barretlino, and I am testing the HMI and I like it so much.
      Are there images or icons libraries?  In order to have a faster development, I would like to have icons libraries.
      Hi, barretlino,
      We have the icon library in the demo project file. Please kindly check.
      @barretlino
      Hi,
      I have a problem with icons:
      I have inserted an icon:
      Then I have inserted another icon.
      This new icon is the same but smaller, called “Programas_Peq”:
      However, when I run the simulation, they are the same size (the smaller the better).
      The first icon simulated (not sure).
      The simulation (OK) of the second icon.
      Can you help me to solve this problem? I need both icons to have the same address because on my system it is the same variable, but the size must be different.
      Kind Regards,
      Barretlino
      • Nigel TianNigel
        Member
        @nigel
        Hi:
        1. Please make a test on the real device. Sometimes the simulation function won’t show the correct result. But on the real device it works normal.
        2. If the real device is also showing the wrong result, please send me your project file so I can check for you.
