Viewing 2 reply threads
    • danieldaniel
      @daniel
      I want to communicate with Arduino through UART. Does anybody know what I should do?
    • Nigel TianNigel
      Member
      @nigel
      Hi Daniel:
      Please check the following article of the Arduino-based demo. It will give you some advise for the communication between our display and Arduino
      https://www.stoneitech.com/news/sharing/arduino-lcd-display-project.html
    • Oscar VeraOscar Vera
      @kokabeto
      This is the same with new software?
        Hi, Oscar,
        That is not the same. Because the command control logic is not the same.
        The command format should be consistent with the command set of STONE Designer which is in JSON code. If you have the new model, the technician should have sent you the command setting instruction document.
