Viewing 2 reply threads
    • MulnoMulno
      @mulno
      I try to send a hex command (e.g. A55A058200010101), but it doesn’t work.
      I recommend that you use the virtual serial port function to test that the project settings are working properly, and then make sure that your program is communicating with the monitor and that it is sending the right commands.
    • MulnoMulno
      @mulno
      Thank you, I tested my virtual serial screen and it didn’t respond, when I changed the settings of the buttons it went back to normal.
