I ordered a STWI070WT-01 touch screen with the USB to UART Converter (v1.5) and I cannot figure out how to connect it to my Arduino Portenta H7. The Arduino is STM32 based and uses 3.3v digital logic rather than 5v. How can I use the adapter to communicate with the display over UART?
You must be logged in to view attached files.To do H7 communicate with Stone display you need only four pins:
+5V, GND, TX (pinJ1-33), RX (pin J1-35) but you cannot connect H7 directly to Stone display. H7 generates TTL signals, display uses RS232 signal. So there’s need of a RS232 to TTL converter. You can use this connections :
terminals R1 IN (13), R1 OUT (12), T1 IN (11), T1 OUT (14) represent relative pins of MAX232 chip (see data sheet). Formly two channel of MAX 232 are used: channel R1 (sends D0 to RX ), channel T1 (sends TX to DI).
MAX 232 chip translates TTL to RS232 and viceversa.
It is desirable to use an external power supply to avoid overload of H7 supply.
You must be logged in to view attached files.come collegare arduino portenta machine control con stone hmi?
I need to use the Stone USB converter to connect a Arduino Portenta H7 to a Stone display 5v . Can you give me a schematic to do it ? Thanks
Hi dear Mauro,
Please check the attached image. You can send email chao@stone-hmi.com or WhatsApp 008613260055123 directly to me for better supports.
Best Regards,
Chao
