Viewing 6 reply threads
    • old_manold_man
      @old_man
      Hi, I’m using the new design software STONE Designer and the new product STWI080WT-01. I do not quite like the default animated icon on boot, I want to replace it with my own company’s icon and apply it to all controls, can I change it? If I can, how should I do it?
      There is a resources-image file library in the bottom left corner of the software, and there are update and delete buttons on the right side of each icon, just update it to your favorite image.
    • Lucas ManciniLucas Mancini
      @mancinilucas95
      Hi,
      i would like to know if you could finally change the default animated icon on boot .
      Greetings
      Yes, the boot animation is not yet open to clients, so you can’t change it yourself for now, but you can contact us and send us the image or animation you want to change and we will make it for you.
      In the future this feature will be open to clients.
        @mancinilucas95
        Ok, thanks!
    • Roger JohnsonRoger Johnson
      @eagle22
      Hi,
      we are using the STWI035WT-01 and the GUI designer version 1.1.4.
      We tried removing the STONE logo at boot like explained in the post above, but there is no STONE image in the resources in the GUI designer.
      Three questions (can you please answer each one separately):
      1) How do we remove completely the STONE word/logo when the display boots up?
      2) where do we download the latest GUI designer version?
      3) in the post above it mentions some boot animation. There is no animation on the display we have. Can you please explain what animation that is referring to.
      Thank you
      • Patricia RenPatricia Ren
        @patricia
        Hello, please look out for your email in which we have answered your question.
      • Richard KilduffRichard Kilduff
        @ecobeast
        Hi, I have a STWA101WT-01 and designer ver 1.1.9. Similar to the above I’d like to change the STONE logo to my own image but I don’t see it in the project download. How can this be changed?
        I also have a problem loading a project I have created onto the display. I can successfully loaded 1024×600 projects I have downloaded from your website and I have been successful loading a very simple project created in the designer. Are there any restrictions around the types of widgets you can place over the top of other widgets?
        Regards
        Richard
        @patricia
        Your two questions will be sent to you in an email with specific steps to follow, please check your email and leave me a message if you do not receive it within two working days.
        Thank you for your cooperation.
    • yasiel cala ferroyasiel cala ferro
      @yasielcf89
      Hello, I have an LCD HMI STONE stwi070wt-01 that got blocked and does not go past the logo and does not load any project please I need help I am new this has only been a few days since I had it and everything was going well I tried to upload a project that I was doing and it stuck please help
    • exorgroupexorgroup
      @exorgroup
      Hi,
      I have a STWI101WT-01 and would like to change the stone logo.  I have uploaded a 24 bit logo to the STONE/logo folder but still have the old logo showing.
        @patricia
        Hello! Thank you for your message.Please check carefully:
        1. Whether the format of the picture you need to replace is bmp, please right-click on the computer properties to check.
        2. Whether you follow the on-screen instructions, i.e., the update progress will be displayed after inserting the USB flash drive, and the prompt will be displayed and restarted automatically after unplugging the USB flash drive.
        If you can Please take a picture of the back of your board, we can also determine whether it is because the version is too old need to be updated to support, thank you for your cooperation!If you still have problems, please contact me.
        Best Regards,
        Chao
        WhatsApp: 008613260055123
        Email: chao@stone-hmi.com
