Viewing 3 reply threads
    • Hyeoncheol ChoiHyeoncheol Choi
      @niro0887
      Hello, I’m trying uart communication between STWI035WT-01 and STM32F446RE.
      And I’d like to change the UART port level of LCD. (I don’t want to apply TTL to RS232 converter)
      Is it right to weld two area(①,②) of TTL? Do I have to remove all(③~⑥) 0Ω resistor in the area of 232?
      Please check and reply.
    • justin beckerjustin becker
      @jbecker4134
      I need an answer for this too.
      • WuChaoWuChao
        @wuchao
        Hi dear Justin,
        I have sent the solution, have you try?  If you have any questions about Purchasing & UI design & Programming, please contact me directly : chao@stone-hmi.com / WSAPP 008613526285568. More than appreciate!
        Best Regards,
        Chao
        Stone Tech
    • WuChaoWuChao
      @wuchao
      Hi dear Hyeoncheol,
      Sorry for your late reply on forum, as you know we already solved your problem days ago.
      Best Regards,
      Chao
      Stone Tech
      @niro0887
      Thank you for your answer.
      I solved the problem, thanks to master’s check.
      For whom this way can help to solve problem,
      I found the ttl/r232 area inside of the lcd cover. (In case of STWI-035, you need to take off cover, and be careful not to break the wire)
      Solderd two ttl areas and removed four rs232 resistors.
      thank you.
