  • Nigel TianNigel
    Member
    @nigel
    Dear Camilo:
    The setting of your font creator has some issue. While you are using the 1251 Latin coding, the font has to be half width, which means the “equivalent width with height” option must be unchecked, and the width should be half of the height, which is 13 in your setting.
    Please fix this and test again.
  • Anonymous
    Nigel, thanks for your kind support, you’re right, it works 100% !!!!!
    Thanks again.
    • Nigel TianNigel
      Member
      @nigel
      You are welcome
