Viewing 2 reply threads
    • AnthohAnthoh
      @anthoh
      I have a STWI010WT-01 that I am trying to make communicate with an Arduino Leonardo.
      I soldered R601, to switch from RS232 to TTL and I am able to send instructions from the Arduino to the screen, but I am unable to receive instructions from the screen to the Arduino.
      Could you help me ?
      Thank you in advance.
    • justin beckerjustin becker
      @jbecker4134
      Im having the same issue.  I can send from the arduino to screen.  But the HMI doesn’t seem to send to the arduino.  below is the code i used.
      void setup() {
      Serial.begin(115200);
      // the loop routine runs over and over again forever:
      void loop() {
      if (Serial.available()){
      int data = Serial.read();
      Serial.write(data);
      • WuChaoWuChao
        @wuchao
        Hi Justin,
        Have you tried the demo which I send you via email? Please let me know how is going. You can reply to my email directly
        chao@stone-hmi.com / WSAPP 008613526285568
        Best Regards,
        Chao
        Stone Tech
    • Allan UrbinaAllan Urbina
      @aurbinacr
      Hi every one, my team and I have the same problem, we can send information to the screen, no problem, but try to get a value from an “edit” in this case, and it doesn´t work at all…
      we don´t get any value or data on the serial monitor as response…
      when connect the display to the UART communication software SSCOMM3.2 we can get data on the screen like:
      43 50 3C 10 72 00 10 41 44 4A 4F 52 40 5E 44 4F 56 41 44 40 00 00 00 3C 45 50 68 A8
      53 54 3C 10 72 00 10 40 44 42 4F 53 50 5F 14 5F 54 40 4C 40 00 00 00 2E 44 54 A9 A0
      43 54 2C 00 30 00 10 41 40 4A 1D 53 40 5B 44 5F 54 40 4C 40 00 00 00 3C 41 54 C9 A8
      53 54 1C 10 62 00 00 41 44 4A 57 53 40 4F 54 5E 54 01 4C 00 00 00 00 3C 44 14 E9 08
      52 04 38 10 30 00 10 01 44 42 5E 11 50 1F 54 57 52 40 0C 40 00 00 00 1E 40 50 E9 88
      this example is typing the number 2 and return every time and as you can see we get different data for example, the “53 54 3C” and “3E 45 54” (“ST<” and “>ET”) should be the same every time, but as you can see it is not the case…
      as mentioned before, we can send information to the screen and show it with no problems, but cant get any data from it.
      in the picture, you can see, what is the edit programing, on the image can see a picture of the screen with the number 2 as value, and in the left can see the SSCOMM3.2 software and the command I am sending to get the value , in the bottom can see a collection of several queries sent with the same information and will see that every response is completely different, and there is no information about this…
      Hope you can guide me to the successful integration of this screen to our projects.
      best regards.
