Viewing 2 reply threads
    • DKScottDKScott
      @dkscott
      Hello Stone
      I am currently developing the STVI070WT-01 screen. I send data to the screen according to the instructions of the data manual, but the screen has not made corresponding changes. In addition, with the routine WS2812B_RGB lamp, Click on the 7-inch display screen to receive a string of incorrect code values. I would like to ask.
      Thank you!
    • DKScottDKScott
      @dkscott
      MCU uses STM32F103ZET6, the wiring mode is the same as the following figure
        Hello dkscott
        Please pay attention to the difference between RS232 and TTL!
      • DKScottDKScott
        @dkscott
        Bancroft
        Thank you for your reply
        I did not use MAX232, but directly connected to the SCM according to the wiring diagram above, and I also directly used another CH430 module to capture the data on the screen
        Because that small board has no schematic diagram, but it can supply power, so I only use it for power supply.
        Thanks!
      I think the logic level is wrong
      The 7 inch display screen of model STVI070WT-01 is RS232 port
      • DKScottDKScott
        @dkscott
        Since there is no schematic on the board, the routine is also directly connected.
        Should be TTL interface, otherwise how directly connected to the SCM direct control
        The MAX232 is the RS232, sent to the computer, but the CH430 is the same
        Is the CH340 set to 5V?
        If I set it to 5V
        You can change it to 3.3V
