I attached instructions from Stone to change the boot logo. If the logo does not change according to this instruction, then you probably have an old display model (as I had) and you need to contact support so that they can help you update the display firmware.
You must be logged in to view attached files.Gentlemen,
This looks simple and I am sure it is, but there is no way I can make it work on my STWA101WT-01… I have to be missing, or misunderstanding, something somewhere, just hope any of you kindly help me find where my mistake is.
Just to be sure, before going any further: Does the content of the U-disk should be STONE\logo\logo.bmp? If that is correct, then the following is what is running me crazy:
1- First, if by “Host” the pdf means what on the PCB is actually labeled as “PC” (at least on my board it is labeled that way), then does it make any sense? I mean, should I select “PC” (Host) instead of U-disk if what I will be actually using is the U-disk?…
2- When I select PC and plug the U-disk in, it does nothing, as expected. If, on the other hand, I select U-disk and plug the U-disk in, then it starts detecting the unit and after a couple of seconds an error message comes always up: “U-disk error, please try again”. I have tried two USB sticks already, always formatting them before use.
If any of you can drop me a quick comment here on this subject, I will appreciate it a lot..!
Thanks,
Alex
Yes, in your case you need to switch to the U-disk. And yes – the directory and filename must be exactly as specified in the document – STONE\logo\logo.bmp .
In addition, the logo.bmp file must have a resolution in pixels that exactly matches the resolution of the display and be saved in 24 bits per pixel format.
Today I receive a new display and I use the same procedure that I did a month ago, but in this case appear a message “File does not exist, please check”.
I create STONE\logo\logo.bmp in the USB. I attach the logo.bmp properties.
I check the sys version of the STWA070wT-01
ST<{“cmd_code”:”sys_version”,”type”:”system”}>ET and is V2.0.07.211119RC
Thanks.
You must be logged in to view attached files.Hello, your version is too old to update the logo. Later, the sales staff will contact you to update the firmware, and the logo can be updated normally after the update.
