Viewing 3 reply threads
    • JF LapradeJF Laprade
      @jflaprade
      i have made the bin and the project folder in the ston folder and copy the assets folder and the assets file but when i put the u disk nothing append. i’m not sure about the files i copy from stone designer?
      I would like to ask what model of screen you are using?
      If you are using a STV series screen, you just need to insert the USB drive into your computer (make sure there are no other files on the USB drive) and click download to USB drive in the UI software interface.
      If you are using the STW series screen, you need to connect the screen to the computer and power it on, then click compile in the UI software to bring up the file directory, click assets in the path, and copy the entire default folder to the screen.
      The bin folder was created as a way to update the firmware, not to copy the project files.
      @jflaprade
      i have copy the entire folder on my u-disk but nothing happend wy shuld the screen have to be connect to the computer ?? i have a power supply it is a stw serie
      Our new products are available for copying files through u-disk or directly from a computer.
      If you use a u disk, the K600 on the back of the screen should be set to HOST; if you copy files directly from your computer, the K600 on the back of the screen should be set to DEVICE.
      Please contact me if you still have questions.
