Viewing 2 reply threads
    • Alex StoneAlex Stone
      @h121
      We recently purchased some STVA070WT-01 screens for a boat dashboard upgrade project. Otherwise the screen feels great for our purposes, but I’m not having luck when trying to connect a computer to the screen using the provided DL-B07 USB/UART adapter plate.
      I’m following this guide: https://www.stoneitech.com/application/application-note/hardware-connection-and-serial-port-communication-test.html
      I can power the screen by connecting 12V to the DL-B07, and when I plug the adapter board’s mini-USB to my computer USB the blue led on the adapter plate turns on.
      I have installed the Silent Labs drivers as instructed in the guide, but when I connect the adapter plate to my computer USB, I can’t see the bridge’s corresponding serial port on my computer. I first tried this on a Macbook pro (Big Sur), but no device appears in /dev/. Then I tried it on a Windows 10 machine, but no COM port appears. I have tried several versions of the OSX and Windows drivers but no luck.
      What am I missing? Thank you in advance for your thoughts!
      @h121
      I managed to solve the issue. There were two problems. First, my USB cable was defective. After trying out a higher quality cable I’m able to see the device in Windows.
      The second issue was the Windows driver. I was not able to get the Silent Labs driver working after multiple attempts, but then searched for the CH340C chip on the adapter plate and found this post http://www.cesareriva.com/usb-to-serial-converter-hl-340-drivers/
      The 64-bit driver linked in the post works perfectly, and now I’m able to communicate with the screen using Stone’s Command Assistant, as described in the guide.
      Hope this helps.
    • Nigel TianNigel
      Member
      @nigel
      Hi Alex:
      Thanks for your information and great effort. We will update the product soon and will have the instruction updated.
      Please let us know if you have any other questions.
