Viewing 2 reply threads
    • gbflyergbflyer
      @gbflyer
      Can you explain variable clocks to me, please?
      The variable clock can only use the clock information provided by the user’s motherboard, send the time information to the serial screen in real time via the serial port, and then display it using the variable clock control.
      The variable clock can only display the clock in text form. The variable clock allocates a variable memory cell, the length of which is measured in BCD code bytes.
      The unit function is used to store time information such as “year, month, day, hour, minute, second, week” sent by the microcontroller.
      BCD code format. The user microcontroller writes the time information such as “year, month, day, hour, minute, second, week” in BCD code format to the variable memory unit by 0x82 instruction. The serial screen will take out the BCD time from the variable unit and display it according to the set display position, color, font and dot matrix size, and the separator between bytes can be set by the customer (for example, it is customary to use an underscore for year, month and day, and a colon for hour, minute and second). Display the BCD code time of one byte, and take a delimiter to show the following
    • 前史蒂夫·威尔金森前史蒂夫·威尔金森
      @formerly_steve_wilkinson
      Looks good, I’m working on a project that has the same problem!
