Is it the future yet? I would like to replace the STONE splash screen with our customer’s logo too.
Hello, we will send you the details of how to do this, so please check your email.
If you do not receive it within two working days please leave me a message, thank you for your cooperation.Hi, I got the instructions. It does not seem to work. If I only put the logo folder in the STONE folder it says “File does not exist” If I include the project file it updated the project but not the logo.
Is it possible that the version I have does not support this function. sys_version returns V2.1.02.211221RC
We will test this together with your other question, please be patient. We will get back to you in an email if we have further results.
Thank you for your cooperation!
This is a very important feature for us… it’s the only thing preventing us from switching to Stone for our HMI components. Could you please send us the instructions as well?
Hello everyone,
I am currently facing a persistent issue with my STONE displays (models STWI070WT-01 and STWI080WT-01) regarding the boot logo. Despite following the manufacturer’s suggested procedure, the default “STONE” logo remains unchanged.
Here’s what I’ve done so far:
1. I accessed the internal memory of the display via USB, treating it as an external disk.
2. I created a directory in the root called “STONE”, and within that, a subdirectory called “logo”, where I placed a 32-bit BMP image named “logo.bmp”. The path looks like this: /STONE/logo/logo.bmp.
3. I’ve attempted reboots and also used the reset button on the back of the display.Despite these steps, the default “STONE” logo continues to appear on boot-up. I even tried using a simple monochrome image to replace the logo with a black screen, but without success.
I suspect there might be some firmware restrictions or specific settings that are not documented. Has anyone here encountered a similar issue? If so, how did you manage to resolve it? Any guidance or suggestions would be greatly appreciated, especially if there’s a particular image format or setting that works.
Thank you all in advance for your help!
Best regards,
Roberto
You must be logged in to view attached files.Hello! Thank you for your detailed description!
Your operation is not a problem, but please note that the logo image needs to meet the 8-bit or 24-bit bmp format image, your 32-bit image is not supported by the update.
You just need to modify the image and update it again, please try it, thanks!
