Hi. I have a STWC043LT-01, I wanted to update the project via USB-A cable.
Had various problems out of the box during transferring images (failed message every time) so I decided to format the U-Disk.
Now the transfer gets completed but after has finished and successfully checked presence of the VT folder on the disk, after the reboot the screen is completely purple.
Have tried several times without effort.
Please help. Best regards
You must be logged in to view attached files.Anyone here?
Thank You
I wanted to transfer the project directly via USB cable, but had every time a nag screen of windows that says “your F: disk has errors – do you want to check and correct the errors?”.
So, looking onto the manual that says to dance all the files I have FAT16 formatted the internal “APP” DISK erasing all the files inside and that once connected to the USB of the computer in recognized as F: and successfully loaded the project now have a VT_SET inside the disk but rebooting nothing appears.
The load is successful but once finished the purple screen appears and no project is loaded. I have attached serial number of the device (have bought it on 03-2023)
Could You please give me support?
Best regards and thanks
You must be logged in to view attached files.Hello Mr.Stefano,
According to your statement, your project was done with TOOL2019 software, right? This is the software for our second generation products STV series and cannot be downloaded on the new product which is STWC043LT-01 without conversion.
If you would like to send me your complete project file, I can convert this file for you.
Please send to: sherry@stone-hmi.com
Best regards
Hi Bancroft.
Yes correct.
I have done it in TOOL2019 since the preproduction unit was done with old screen and the new Software Stone Design had various crashes unable to finish the project.
If You could send me the converted version of the project it would be very nice since I do not need to make it from scratch.
Best regards
