  • stoneitechstoneitech
    @forum
    Hello, don’t use SoftwareSerial first, try using the default serial port of Arduino
    • Yogesh KumarYogesh Kumar
      @scitivex
      Yes tried but not working.
      @scitivex
      Please help. Thank you
  • bowei zhangbowei zhang
    @zbw3366
    Switch the screen to TTL level
      @scitivex
      Ok. But please explain. How ?
  • Lollo71Lollo71
    @lollo71
    May be you’re using a RS232 UART display. In this case you need a level adaptor in order to communicate with Arduino that instead uses a TTL level UART
    @scitivex
    What other hardware would be required to communicate it with Arduino?
    However, all the UART devices I have worked with so far are directly connected to the arduino with the help of only 2 tx and rx pins.
      Dear Yogesh Kumar,
      Please refer to this connection diagram.
    @scitivex
    Yes, I also have the same circuit. But still why the test code I shared above is not working. Is there any problem with the code.
    Please share if you have any test code. Thank you
      Dear Yogesh,
      Have you changed RS232 to TTL interface?
      Could you please show me the back of the screen?
      I will check your interface and tell you how to change the interface.
      Best regards
      @scitivex
      Please Help how to change 232 to TTL
      Dear Yogesh,
      Please refer to the picture.
