Initially I started a new project and when I did that all was good. I could see all the canned resources that would allow me to place objects on my screen design and everything looked good. I added some resources/images I designed myself for my project in addition I places a few buttons and text boxes on my screen that would be used for input and so forth. Everything looked great. I was able to follow the instructions to a T and get my screen design copied to my LCD screen and it looked great. I saved my project and did not think about it again. This morning I attempted to open my project and all I saw were the resources I added I do not see the rest of the resources. The problem now I want to add some new resources like a check box but the only thing I see when I drop the check box onto my design is the wording “checkbutton” I don’t actually get the check box itself. The only thing I see listed under images in the resources are the images I added myself.
If anyone knows how to fix this or has seen this too please let me know how to fix it.
You must be logged in to view attached files.Hi,
Have you deleted the resources in the bottom left corner?Or if you have performed operations such as forced shutdown?Hi, No I did not delete any resources. I don’t recall doing a forced shutdown. Normally I have been saving my project and then closing the designer. Is there anyway to get the normal project resources back without having to start my project all over again. I did start a new project to see what would happen and all the resources that are normally were back. They are just missing from the project I had been working on.
Thanks
David
We have understood your situation.
We will contact you tomorrow.
ok thank you. I did just try one thing and it worked. When I was done designing my project the other day I downloaded it so that I could copy the default folder to my screen. I noticed when I downloaded it that it created a folder with all the resources. I could not find the resources anywhere else but when I looked in the default folder the download created I can see a folder in the path default\raw\images within there are 5 folders: svg, x1, x2,x3 and xx. I can see what looks like all the resources in there. In the designer I choose to add resources and then picked the x3 folder, selected them all and it looks like they all were added back. How do I know if the x3 is the correct folder to perform this on? I see it looks like the resources are duplicated in each of the folders x2, x3 amd xx folder. There is nothing in the x1 folder or svg folder.
Thanks
David
