Viewing 3 reply threads
    • Francesco FiaccabrinoFrancesco Fiaccabrino
      @minimo55
      Hi everyone,
      Please be aware that downloading stone serial library from github site of Stone Tecnology, according to procedure described in the manual “Instructions for Stone uart library.pdf” is dangerous. If you download, for example, “stone.h” o “stone_config.h” files directly from “examples” folders, you will receive higly corrupted files that are unuseful (probably because someone altered them). Even the README.md file is. My hint to download safe files is: to right click “Code” green button to the high left then to click “Download .zip” file. So doing you will obtain uncorrupted file, esamples, sources, ecc. to use stone serial library.
    • bowei zhangbowei zhang
      @zbw3366
      How do you download a single file?
      @minimo55
      @ bowei zhang
      “Download.zip” is to download “all” files from github repository. It doesn’t require much time. After done, simply choose the file of your interest (inside example, Inc or Src directory). Example contains applications for arduino or stm32 systems, Inc contains important files such as stone.h and stone.config.h extremely necessary to use stone serial library. Src contains stone_receive.h and stone_transport.h. You need all these files to make stone serial library working.
      @zbw3366
      OK, thank you.
