Fiona LiuFiona Liu
Dear sir,
1. You can check our instruction set as below and just add Set or Turn off sleep mode when you are programming.
If no instruction is detected to be sent within 5 minutes, it goes into sleep mode; once an instruction is detected, sleep mode is turned off.
2. I have attached the document where you can change the logo, please check it out.
