Kathleen NguyenKathleen Nguyen
@kathnguyen
How do I make sure the adapters are set to RS232? I attached a picture showing the set up to the computer. Also when I apply code at the terminal would I just send a command like this?
ST<{“cmd_code”:”set_value”,”type”:”line_series”,”widget”:”line_series1″,”index”:4,”value”:38}>ET
