LCD-TFT Display User Interface Design
First of all, we need to design a UI display picture, you can use PhotoShop software to design it, or you can use other graphic design tools to design it, after designing the UI display picture, save the picture as JPG format.
Open STONE TOOL2019 software and create a new project.
Remove the image loaded by default from the new project, and add the UI image we designed.
Add the text display component, design the number of digits and decimal points of the display, and get the location where the text display component is stored in the display.
The result is as follows:
Addresses, keys and values of text display components.
open : 0020 0001
close : 0020 0002
Generating Configuration Files
After the above UI design is completed, you can generate the configuration file, and then download the configuration file to the STVI070WT display, this part of the operation is introduced in the STONE development materials.
Then click “Download to u-disk” to download the configuration file to u-disk, and then insert the u-disk into STVC070WT, you can finish the upgrade.
