bowei zhangbowei zhang
@zbw3366
If you set the spin_box input type to int, then the four bytes of 00 00 00 5B will be the data bit. The serial port library will store the four bytes of data in the variable STONER. Long_value. So all you need to do is assign this variable to your user variable
