The place marked 2 in the figure should be 3.3v, is to power the cpu and other circuits, that circuit in the shield, it may be you solder 5v shorting point and then power the 12v voltage, which leads to 3.3v power chip burned, It may not be very easy to repair.
Our sales staff will be in contact with you via email later, so please check your inbox.
