POLE_BENDERPOLE_BENDER
@pole_bender
Hi Lin,
– Ok, It’s now clear, this type of display can only be loaded by Udisk (J10), thank you bancroft
– I reformatted my memorystick (fat32): do not change anything
– If I slightly modify ,on my USB memory stickor on the C drive, a pjd with Paint, it remains accepted
– I wanted to try on another 32b Win7 pc, but not possible to install the software, always receive the message “the software license as expired ….” despite the execution of the instructions (Mscomm32.ocx and register.cmd)
After a lot of test and comparaisons…Good news !!!
I noticed that when I perform “generating configuration file” then “download on USB”, the “VT_SET” directory which copies to the USB memory stick contains 1 more file: “Checksum.bin”
If I delete this file before inserting the USB memory stick into the J10, everything is copied! ?
Contents of this file: “0.JPG Qî0.WAV 1.JPG y 10.JPG a“ 11.JPG s% 12.JPG [k13.JPG ÑŸ14.JPG i | 15.JPG w 16.JPG © o17.JPG ‘“18.JPG õ19.JPG ŒÚ2.JPG 20.JPG 621.JPG DS22.BIN <22.JPG Êi23.JPG ˜ 24.ICO j 24.JPG ó 25.JPG û © 26.JPG * Ý27.JPG ¾ 28.JPG “Ï29.JPG
ž3.JPG Â 30.JPG * 31.JPG ÁY32.JPG Ú 33.JPG îå34.DZK… / 34.JPG (35.JPG | š36.JPG 8®37.JPG ‘4.JPG’ 40 .ICO ûh41.ICO U • 5.JPG ê “52.JPG FY6.JPG <66.DZK * Ÿ7.JPG. 8.JPG 5Ý9.JPG N„ CONFIG.txt U VGUSII.bin Ÿ ”
Does that mean anything to you?
Regards, Roland
