Thank you very much for your patience with my requests.
I still have one last obstacle before I leave you alone ?:
First of all, on this (mine) type of display, I can only load a new configuration via U disk ? because the fast download uses the mini usb which does not exist: True or False?
These last days, I made a lot of tests and here are the results:
Via U disk : if I copy The “VT_set” directory of the “800×480 test project” from your USB memory stick delivered with the display to a other USBmemory stick (mine) and put it on J10 USBsocket: Everything loads impeccably
On the other hand, if I open in TOOLS 4.3 the file “800×480 Test Project. Vt” of this same configuration, and that I make a small modification (move an element slightly of place),
I save, I execute “Generating configuration File” and I “Download to USB” with Usb melmory stick (Completely empty) well recognized: “Download all files succesfully”
When the stick is introduced in J10, the old files are deleted, but when copying “E: \ VT_SET \ 0.jpg CRC error -usb!”
it seems that the generation of the VT_SET poses a problem?
I am under Win10.
Promised, this problem solved, I stop boring you and order other displays?
Reply To: I don't Know where I can connect or find the RS232 signalPOLE_BENDER2021-10-19T16:38:07+08:00
