To rotate the project 90 degrees, you must create a new project and set it at the beginning:
All your interface images must be rotated (for example, if your monitor is 800*480, your image resolution must be 480*800)
You can also see that there were similar problems before.
https://forum.stoneitech.com/topic/rotate-the-item-90-degrees/
