Thank you for your answer!
I need to ask you about a particular problem. The last few days I used the button type “Button key-value return” on my project and I asked for the button´s direction, this way worked well, but my project requires to do many tasks so sometimes the microcontroller is not able to read the address when the button was pressed. to guarantee the read I used the button type “Incremental adjustment” and on my code, I ask for the value stored on this button. This way is a good option but I need to ask for the state of various buttons at the same time and when I verify the state of each button and I press any of the buttons their status affects that of others.
On the Image1 I use the incremental adjustment0 button to change to the Image2, and on the Image2 I use the incremental adjustment1 to change to the Image1, only when the state is 1. when a button happens I reset the other, but the images change intermittently as I show you on the video. I attached the code in case you find something I’m not doing right and let me know or if there is another way to do the process.
Thank you for your help.
Steve
