I have other questions that I want to ask you if it is possible to change the screen image from code without putting any button.
For example, in the attached image I put a button with the key code 1 and I send the command: 0xA5, 0x5A, 0x03, 0x80, 0x4F, 0x01 from code to change the image, but I don’t want to put these buttons because it is possible that the user presses the screen where the button is and the process would be interrupted.
Thank you for your help.
Steve
