Fiona LiuFiona Liu
Hi  ikarcuaso
Here’s the demo,
Real-time time graph on STONE TOOLBOX
The X value will be the data input, which is the normal variable value.
You could say 222.0 is 0 on the X-axis. Once the data source starts entering data (Y values), the curve starts here.
The values of X are entered into variable memory addresses as Settings.
The X value will be the data input, which is the normal variable value.  You could say 222.0 is 0 on the X-axis.Once the data source starts entering data (Y values), the curve starts here. The values of X are entered into variable memory addresses as Settings.
