Real-time curve project implementation process
LCD-TFT display user interface design
Open the STONE TOOL 2019 software and create a new project.
The maximum value of the curve in this design is 50
Add the Live Curve component.
Vertical axis magnification: height*255/50 (the maximum value set)
Y Central : height/2+ Y coordinates
VD Central: 25 (half of the maximum value)
Generating the configuration file
Once the above UI design is complete, the configuration file can be generated and then downloaded to the STVI070WT display, this part of the operation is described in the STONE development material.
First perform step 1, then insert a USB stick into your PC, the disk character will be displayed, then click on “Download to u-disk” to download the configuration file to the USB stick, then insert the USB stick into the STVC070WT to complete the upgrade.
